no <PARAMETER>
no <PARAMETER>
| no <PARAMETER> | Specify the parameter details to remove or revert to default |
The following example shows the neighbor 192.168.13.99 settings before the ‘no‘ commands are executed:
ExtremeWireless WiNG(config-profile testNX9000-router-bgp-neighbor-192.168.13.99)#show context bgp neighbor 192.168.13.99 advertisement-interval 100 allowas-in 10 attribute-unchanged as-path capability orf prefix-list both default-originate description neighbor "This neighbor is an external AS neighbor" disable-connected-check dont-capability-negotiate ebgp-multihop 20 enforce-multihop local-as 20 no-prepend maximum-prefix 400 50 warning-only next-hop-self ExtremeWireless WiNG(config-profile testNX9000-router-bgp-neighbor-192.168.13.99)#
ExtremeWireless WiNG(config-profile testNX9000-router-bgp-neighbor-192.168.13.99)#no advertisement-interval
ExtremeWireless WiNG(config-profile testNX9000-router-bgp-neighbor-192.168.13.99)#no disable-connected-check
ExtremeWireless WiNG(config-profile testNX9000-router-bgp-neighbor-192.168.13.99)#no default-originate
ExtremeWireless WiNG(config-profile testNX9000-router-bgp-neighbor-192.168.13.99)#no local-as
ExtremeWireless WiNG(config-profile testNX9000-router-bgp-neighbor-192.168.13.99)#show context bgp neighbor 192.168.13.99 allowas-in 10 attribute-unchanged as-path capability orf prefix-list both description neighbor "This neighbor is an external AS neighbor" dont-capability-negotiate ebgp-multihop 20 maximum-prefix 400 50 warning-only next-hop-self ExtremeWireless WiNG(config-profile testNX9000-router-bgp-neighbor-192.168.13.99)#
