Use the (config) instance to configure device specific parameters
To navigate to this instance, use the following commands:
<DEVICE>(config)#<DEVICE-TYPE> <MAC>
<DEVICE>(config-device-<MAC>)#?
Device Mode commands:
adopter-auto-provisioning-policy-lookup Use centralized auto-provisioning
policy when adopted by another
controller
adoption Adoption configuration
adoption-mode Configure the adoption mode for the
access-points in this RF-Domain
adoption-site Set system's adoption site
alias Alias
application-policy Application Policy configuration
area Set name of area where the system
is located?
arp Address Resolution Protocol (ARP)
auto-learn Auto learning
autogen-uniqueid Autogenerate a unique id
autoinstall Autoinstall settings
bridge Ethernet bridge
captive-portal Captive portal
cdp Cisco Discovery Protocol
channel-list Configure channel list to be
advertised to wireless clients
cluster Cluster configuration
configuration-persistence Enable persistence of configuration
across reloads (startup config
file)
contact Configure the contact
controller WLAN controller configuration
country-code Configure the country of operation
critical-resource Critical Resource
crypto Encryption related commands
database Database command
device-upgrade Device firmware upgrade
device-onboard Device-onboarding configuration
dot1x 802.1X
dpi Enable Deep-Packet-Inspection
(Application Assurance)
dscp-mapping Configure IP DSCP to 802.1p
priority mapping for untagged
eguest-server Enable EGuest Server functionality
frames
email-notification Email notification configuration
enforce-version Check the firmware versions of
devices before interoperating
environmental-sensor Environmental Sensors Configuration
events System event messages
export Export a file
file-sync File sync between controller and
adoptees
floor Set the floor within a area where
the system is located
geo-coordinates Configure geo coordinates for this
device
gre GRE protocol
hostname Set system's network name
http-analyze Specify HTTP-Analysis configuration
interface Select an interface to configure
ip Internet Protocol (IP)
ipv6 Internet Protocol version 6 (IPv6)
l2tpv3 L2tpv3 protocol
l3e-lite-table L3e lite Table
lacp LACP commands
layout-coordinates Configure layout coordinates for
this device
led Turn LEDs on/off on the device
led-timeout Configure the time for the led to
turn off after the last radio state
change
legacy-auto-downgrade Enable device firmware to auto
downgrade when other legacy devices
are detected
legacy-auto-update Auto upgrade of legacy devices
license License management command
lldp Link Layer Discovery Protocol
load-balancing Configure load balancing parameter
location Configure the location
logging Modify message logging facilities
mac-address-table MAC Address Table
mac-auth 802.1X
mac-name Configure MAC address to name
mappingss
management-server Configure management server address
memory-profile Memory profile to be used on the
device
meshpoint-device Configure meshpoint device
parameters
meshpoint-monitor-interval Configure meshpoint monitoring
interval
min-misconfiguration-recovery-time Check controller connectivity after
configuration is received
mint MiNT protocol
mirror Mirroring
mpact-server MPACT server configuration
neighbor-inactivity-timeout Configure neighbor inactivity
timeout
neighbor-info-interval Configure neighbor information
exchange interval
no Negate a command or set its
defaults
noc Configure the noc related setting
nsight NSight
nsight-sensor Enable sensor for Nsight
ntp Ntp server A.B.C.D
offline-duration Set duration for which a device
remains unadopted before it
generates offline event
otls Omnitrail Location Server
override-wlan Configure RF Domain level overrides
for wlan
power-config Configure power mode
preferred-controller-group Controller group this system will
prefer for adoption
preferred-tunnel-controller Tunnel Controller Name this system
will prefer for tunneling extended
vlan traffic
radius Configure device-level radius
authentication parameters
raid RAID
remove-override Remove configuration item override
from the device (so profile value
takes effect)
rf-domain-manager RF Domain Manager
router Dynamic routing
rsa-key Assign a RSA key to a service
sensor-server AirDefense sensor server
configuration
slot PCI expansion Slot
spanning-tree Spanning tree
timezone Configure the timezone
traffic-class-mapping Configure IPv6 traffic class to
802.1p priority mapping for
untagged frames
traffic-shape Traffic shaping
trustpoint Assign a trustpoint to a service
tunnel-controller Tunnel Controller group this
controller belongs to
use Set setting to use
vrrp VRRP configuration
vrrp-state-check Publish interface via OSPF/BGP only
if the interface VRRP state is not
BACKUP
wep-shared-key-auth Enable support for 802.11 WEP
shared key authentication
zone Configure Zone name
clrscr Clears the display screen
commit Commit all changes made in this
session
do Run commands from Exec mode
end End current mode and change to EXEC
mode
exit End current mode and down to
previous mode
help Description of the interactive help
system
revert Revert changes
service Service Commands
show Show running system information
write Write running configuration to
memory or terminal
The following table summarizes device configuration mode commands:
| Command | Description |
| adopter-auto-provisioning-policy-lookup | Enables the use of a centralized auto provisioning policy on this device |
| adoption | Configures a minimum and maximum delay time in the initiation of the device adoption process |
| adoption-site | Sets the device‘s adoption site name |
| alias | Configures network, VLAN, and service aliases on a device |
| antenna-id ap410e | Configures the antenna ID on the AP410e model access point profile or device contexts. Use this command to specify the antenna group and the antenna type used with the selected antenna ports. |
| antenna-id ap460e | Configures the antenna ID on the AP460e model access point profile or device contexts. Use this command to specify the antenna group and the antenna type used with the selected antenna ports. |
| antenna-id (ap510e) | Configures the antenna ID in the AP510e model access point profile and device contexts. Use this command to specify the antenna group and the antenna type used with the selected antenna ports. |
| antenna-id (ap560h) | Configures the antenna ID in the AP560h model access point profile and device contexts. Use this command to specify which internal antenna to use (30/70 degree) and enable the access point radios. |
| application-policy | Associates a RADIUS server provided application policy with this device. When associated, the application policy allows wireless clients (MUs) to always find the RADIUS-supplied application policy in the dataplane. |
| area | Sets the name of area where the system is deployed |
| arp | Configures ARP parameters |
| auto-learn | Enables controllers or service platforms to maintain a local configuration record of devices requesting adoption and provisioning. The command also enables learning of a device‘s host name via DHCP options. |
| autogen-uniqueid | When executed in the device configuration mode, this command generates a unique ID for the logged device |
| autoinstall | Autoinstalls firmware image and configuration setup parameters |
| bridge | Configures Ethernet Bridging parameters |
| captive-portal | Configures captive portal advanced Web page upload on this profile |
| cdp | Operates CDP on the device |
| channel-list | Configures channel list advertised to wireless clients |
| cluster | Sets cluster configuration |
| configuration-persistence | Enables configuration persistence across reloads |
| contact | Sets contact information |
| controller | Configures a WLAN‘s wireless controller or service platform |
| country-code | Configures wireless controller or service platform‘s country code |
| critical-resource | Monitors user configured IP addresses and logs their status |
| crypto | Configures data encryption protocols and settings |
| database | Backs up captive-portal and/or NSight database to a specified location and file and configures a low-disk-space threshold value |
| device-upgrade | Configures device firmware upgrade settings on this device |
| diag | Enables looped packet logging |
| dot1x | Configures 802.1x standard authentication controls |
| dpi | Enables Deep Packet Inspection (DPI) on this device |
| dscp-mapping | Configures IP Differentiated Services Code Point (DSCP) to 802.1p priority mapping for untagged frames |
| eguest-server (VX9000 only) | Enables the EGuest daemon when executed without the ‘host‘ option |
| eguest-server (NOC Only) | Points to the EGuest server, when executed along with the ‘host‘ option |
| email-notification | Configures e-mail notification settings |
| enforce-version | Checks the device firmware version before attempting connection |
| events | Enables system event message generation and forwarding |
| export | Enables export of startup.log file after every boot |
| file-sync | Configures parameters enabling syncing of trustpoint/wireless-bridge certificate between the staging-controller and its adopted access points |
| floor | Sets the floor name where the system is located |
| geo-coordinates | Configures the geographic coordinates for this device |
| gre | Enables GRE tunneling on this device |
| hostname | Sets a system's network name |
| http-analyze | Enables HTTP analysis on this device |
| interface | Selects an interface to configure |
| ip | Configures IPv4 components |
| ipv6 | Configures IPv6 components |
| l2tpv3 | Defines the Layer 2 Tunnel Protocol (L2TP) protocol for tunneling Layer 2 payloads using Virtual Private Networks (VPNs) |
| l3e-lite-table | Configures L3e Lite Table with this profile |
| lacp | Configures an LACP-enabled peer‘s system-priority value. LACP uses this system-priority value along with the peer‘s MAC address to form the peer‘s system ID. |
| layout-coordinates | Configures layout coordinates |
| led | Turns LEDs on or off |
| led-timeout | Configures the LED-timeout timer in the device or profile configuration mode |
| license | Adds device feature licenses |
| lldp | Configures Link Layer Discovery Protocol (LLDP) settings for this device |
| load-balancing | Configures load balancing parameters. |
| location | Configures the system‘s location (place of deployment) |
| location-server | Configures the ExtremeLocation server‘s hostname in the AP's device context. |
| location-tenantid | Configures the ExtremeLocation Tenant‘s account number in the selected AP's device context. |
| logging | Enables message logging |
| mac-address-table | Configures the MAC address table |
| mac-auth | Enables 802.1x authentication of hosts on this device |
| mac-name | Configures MAC address to device name mappings |
| management-server | Configures a management server with this profile |
| meshpoint-device | Configures meshpoint device parameters |
| meshpoint-monitor-interval | Configures meshpoint monitoring interval |
| min-misconfiguration-recovery-time | Configures the minimum device connectivity verification time |
| mint | Configures MiNT protocol settings |
| misconfiguration-recovery-time | Verifies device connectivity after a configuration is received |
| neighbor-inactivity-timeout | Configures neighbor inactivity timeout value |
| neighbor-info-interval | Configures the neighbor information exchange interval |
| no (url-filter-config-mode-commands) | Negates a command or resets values to their default settings |
| noc | Configures NOC settings |
| nsight | Configures NSight database statistics related parameters. Use this command to set the interval at which data is updated by the RF Domain managers to the NSight server. This command is applicable only on the NX95XX series and NX9600 service platforms and is configured on the NSight server. |
| ntp | Configures NTP server settings |
| offline-duration | Sets the duration, in minutes, for which a device remains unadopted before it generates offline event |
| override-wlan | Configures WLAN RF Domain level overrides on the logged device |
| power-config | Configures power mode features |
| preferred-controller-group | Specifies the wireless controller or service platform group the system prefers for adoption |
| preferred-tunnel-controller | Configures the tunnel wireless controller or service platform preferred by the system for tunneling extended VLAN traffic |
| radius | Configures device-level RADIUS authentication parameters |
| remove-override | Removes device overrides |
| rf-domain-manager | Enables the RF Domain manager |
| router | Configures dynamic router protocol settings. |
| rsa-key | Assigns a RSA key to SSH |
| sensor-server | Configures an AirDefense sensor server |
| spanning-tree | Enables spanning tree commands on the logged device |
| traffic-class-mapping | Maps the IPv6 traffic class value of incoming IPv6 untagged packets to 802.1p priority |
| traffic-shape | Enables traffic shaping and configures traffic shaping parameters on this device |
| trustpoint (device-config-mode) | Assigns trustpoints to validate various services, such as HTTPS, RADIUS CA, RADIUS server, external LDAP server, etc. |
| timezone | Configures wireless controller or service platform‘s time zone settings |
| tunnel-controller | Configures the tunneled WLAN (extended VLAN) wireless controller or service platform‘s name |
| use (profile/device-config-mode-commands) | Associates different policies and settings with this device |
| vrrp | Configures VRRP group settings |
| vrrp-state-check | Publishes interface via OSPF or BGP based on Virtual Router Redundancy Protocol (VRRP) status |
| wep-shared-key-auth | Enables support for 802.11 WEP shared key authentication |
| raid | Enables alarm on the array. This command is supported only on the NX9500 series service platform. |
Section contents:
