Each WLAN QoS policy has a set of parameters which it groups into categories, such as management, voice and data. Packets within each category are processed based on the weights defined for each WLAN.
Use the (config) instance to configure WLAN QoS policy commands. To navigate to the WLAN QoS policy instance, use the following commands:
<DEVICE>(config)#wlan-qos-policy <POLICY-NAME>
nx9500-6C8809(config)#wlan-qos-policy test nx9500-6C8809(config-wlan-qos-test)#? WLAN QoS Mode commands: accelerated-multicast Configure accelerated multicast streams address and forwarding QoS classification classification Select how traffic on this WLAN must be classified (relative prioritization on the radio) multicast-mask Egress multicast mask (frames that match bypass the PSPqueue. This permits intercom mode operation without delay even in the presence of PSP clients) no Negate a command or set its defaults qos Quality of service rate-limit Configure traffic rate-limiting parameters on a per-wlan/per-client basis svp-prioritization Enable spectralink voice protocol support on this wlan voice-prioritization Prioritize voice client over other client (for non-WMM clients) wmm Configure 802.11e/Wireless MultiMedia parameters clrscr Clears the display screen commit Commit all changes made in this session do Run commands from Exec mode end End current mode and change to EXEC mode exit End current mode and down to previous mode help Description of the interactive help system revert Revert changes service Service Commands show Show running system information write Write running configuration to memory or terminal nx9500-6C8809(config-wlan-qos-test)#
Section contents:
