data-rates
interface-config-radio-instance
Configures the 802.11 data rates on this radio
This command sets the rate options depending on the 802.11 protocol and the radio band selected. If 2.4 GHz is selected as the radio band, select separate 802.11b, 802.11g and 802.11n rates and define how they are used in combination. If 5.0 or 6 GHz is selected as the radio band, select separate 802.11a and 802.11n rates then define how they are used together.
If dedicating the radio to either 2.4, 5.0, or 6 GHz support, use the custom keyword to set a 802.11n MCS (modulation and coding scheme) in respect to the radio‘s channel width and guard interval. A MCS defines (based on RF channel conditions) an optimal combination of rates, bonded channels, multiple spatial streams, different guard intervals and modulation types. Clients can associate as long as they support basic MCS (as well as non-11n basic rates).
Data rates are fixed and not user configurable for radios functioning as sensors.
Use the rf-mode command to configure a radio‘s mode of operation.
Syntax
data-rates (b-only|g-only|a-only|bg|bgn|gn|an|anc|gnx|ancx|ax|default|custom|mcx]
data-rates (b-only|g-only|a-only|bg|bgn|gn|an|anc|gnx|ancx|ax|default]
data-rates custom [1|2|5.5|6|9|11|12|18|24|36|48|54|mcs-1s|mcs-2s|mcs-3s|basic-1|basic-2|
basic-5.5|basic-6|basic-9|basic-11|basic-12|basic-18|basic-24|basic-36|basic-48|basic-54|basic-mcs-1s]
data-rates mcs qam-only
Parameters
data-ratesConfigures the 802.11 data rates on this radio
b-onlySupports operation in the 802.11b mode only (applicable for 2.4, 4.9 and 6.0 GHz bands)
g-onlyUses rates that support operation in the 802.11g mode only (applicable for 2.4, 4.9 and 6.0 GHz bands)
a-onlyUses rates that support operation in the 802.11a mode only (applicable for 5.0 and 6.0 GHz bands only)
bgUses rates that support 802.11b and 802.11g wireless clients (applicable for 2.4, 4.9 and 6.0 GHz bands)
bgnUses rates that support 802.11b, 802.11g, and 802.11n wireless clients (applicable for 2.4, 4.9 and 6.0 GHz bands)
gnUses rates that support 802.11g and 802.11n wireless clients (applicable for 2.4, 4.9 and 6.0 GHz bands)
anUses rates that support 802.11a and 802.11n wireless clients (applicable for 5.0 and 6.0 GHz bands only)
ancUse rates that support radio mode anc (applicable for 5.0 and 6.0 GHz bands only).
gnxUse rates that support radio mode gnx (applicable for 2.4, 4.9 and 6.0 GHz bands).
ancxUse rates that support radio mode ancx (applicable for 5.0 and 6.0 GHz bands only).
axUse rates that support radio mode ax (applicable for 6.0 GHz band only).
defaultEnables the default data rates according to the radio‘s band of operation
data-rates custom [1|2|5.5|6|9|11|12|18|24|36|48|54||mcs-1s|mcs-2s|mcs-3s|basic-1|basic-2|
customConfigures a list of data rates by specifying each rate individually. Use 'basic-' prefix before a rate to indicate it‘s used as a basic rate (For example, 'data-rates custom basic-1 basic-2 5.5 11')
  • 1 – 1-Mbps
  • 2 – 2-Mbps
  • 5.5 – 5.5-Mbps
  • 6 – 6-Mbps
  • 9 – 9-Mbps
  • 11 – 11-Mbps
  • 12 – 12-Mbps
  • 18 – 18-Mbps
  • 24 – 24-Mbps
  • 36 – 36-Mbps
  • 48 – 48-Mbps
  • 54 – 54-Mbps
  • mcs-1s – Applicable to 1-spatial stream data rates
  • mcs-2s – Applicable to 2-spatial stream data rates
  • mcs-3s – Applicable to 3-spatial stream data rates
  • basic-1 – Basic 1-Mbps
  • basic-2 – Basic 2-Mbps
  • basic-5.5 – Basic 5.5-Mbps
  • basic-6 – Basic 6-Mbps
  • basic-9 – Basic 9-Mbps
  • basic-11 – Basic 11-Mbps
  • basic-12 – Basic 12-Mbps
  • basic-18 – Basic 18-Mbps
  • basic-24 – Basic 24-Mbps
  • basic-36 – Basic 36-Mbps
  • basic-48 – Basic 48-Mbps
  • basic-54 – Basic 54-Mbps
  • basic-mcs-1s – Modulation and Coding Scheme data rates for 1 Spatial Stream
    Note: Refer to the Usage Guidelines Usage Guidelines (Supported data rates) section for 802.11an and 802.11ac MCS detailed dates rates for both with and without SGI (short guard intervals).
mcs qam-onlyConfigures supports for MCS QAM data rates only
The following table defines the 802.11n MCS for MCS 1 streams, both with and without SGI:
MCS-1Stream IndexNumber of Streams20 MHz No SGI20 MHz With SGI40 MHz No SGI20 MHz With SGI
016.57.213.515
111314.42730
2119.521.740.545
312628.95460
413943.48190
515257.8108120
6158.565121.5135
716572.2135150
The following table defines the 802.11n MCS for MCS 2 streams, both with and without SGI:
MCS-2Stream IndexNumber of Streams20 MHz No SGI20 MHz With SGI40 MHz No SGI20 MHz With SGI
021314.42730
122628.95460
223943.48190
325257.8108120
427886.7162180
52104115.6216240
62117130243270
72130144.4270300
The following table defines the 802.11n MCS for MCS 3 streams, both with and without SGI:
MCS-3Stream IndexNumber of Streams20 MHz No SGI20 MHz With SGI40 MHz No SGI20 MHz With SGI
0319.521.740.545
133943.38190
2358.565121.5135
337886.7162180
43117130.7243270
53156173.3324360
63175.5195364.5405
73195216.7405450
The following table defines the 802.11ac MCS rates (theoretical throughput for single spatial streams) both with and without SGI:
MCS Index20 MHz No SGI20 MHz With SGI40 MHz No SGI40 MHz With SGI80 MHz No SGI80 MHz No SGI
06.57.213.51529.332.5
11314.4273058.565
219.521.740.54587.897.5
32628.95460117130
43943.38190175.5195
55257.8108120234260
658.565121.5135263.3292.5
76572.2135150292,5325
87886.7162180351390
9N/AN/A180200390433.3
nx9500-6C8809(config-profile-510TestProfile-if-radio1)#data-rates b-only
nx9500-6C8809(config-profile-510TestProfile-if-radio1)#show context
 interface radio1
  channel 1
  data-rates b-only
  beacon period 50
  beacon dtim-period bss 1 5
  beacon dtim-period bss 2 2
  beacon dtim-period bss 3 5
  beacon dtim-period bss 13 5
  beacon dtim-period bss 14 5
  beacon dtim-period bss 15 5
  beacon dtim-period bss 16 5
  antenna-gain 12.0
  aggregation ampdu tx-only
  aeroscout forward
  --More--
Related Commands
no (radio-interface-config-command)Resets the 802.11 data rates on a radio
rf-modeConfigures the radio‘s RF mode of operation
