l2tpv3
Profile Config Commands
Defines the L2TPV3 settings for tunneling layer 2 payloads using VPNs
L2TPv3 is an IETF standard that defines the control and encapsulation protocol settings for tunneling layer 2 frames in an IP network (and access point profile) between two IP nodes. Use L2TPv3 to create tunnels for transporting layer 2 frames. L2TPv3 enables WiNG supported controllers and access points to create tunnels for transporting Ethernet frames to and from bridge VLANs and physical ports. L2TPv3 tunnels can be defined between WiNG devices and other vendor devices supporting the L2TPv3 protocol.
Syntax
l2tpv3 [hostname <HOSTNAME>|inter-tunnel-bridging|logging|manual-session|router-id [<1-4294967295>|<IP]|tunnel|udp-listen-port <1024-65535>]
l2tpv3 logging ip-address [<IP>|any] hostname [<HOSTNAME>|any] router-id [<IP>|<WORD>|any]
Parameters
l2tpv3 [hostname <HOSTNAME>|inter-tunnel-bridging|manual-session|
router-id [<1-4294967295>|<IP>]|tunnel|udp-listen-port <1024-65535>]
l2tpv3Configures the L2TPv3 protocol settings for a profile
hostname <HOSTNAME>Configures the host name sent in the L2TPv3 signaling messages. Tunnel establishment involves exchanging 3 message types (SCCRQ, SCCRP, and SCCN) with the peer. Tunnel IDs and capabilities are exchanged during the tunnel establishment with the host.
  • <HOSTNAME> – Specify the L2TPv3 specific host name.
inter-tunnel-bridgingEnables inter tunnel bridging of packets. This feature is disabled by default.
manual-sessionCreates/modifies L2TPv3 manual sessions
For more information, see l2tpv3-manual-session-commands.
router-id [<1-4294967295>| <IP>]Configures the router ID (either the numeric IP address or the integer) sent in the L2TPv3 signaling messages. These signaling (AVP) messages help to identify tunneled peers.
  • <1-4294967295> – Configures the router ID in decimal format from 1 - 4294967295
  • <IP> – Configures the router ID in the IP address (A.B.C.D) format
tunnelCreates/modifies an L2TPv3 tunnel
For more information, see l2tpv3-tunnel-commands.
udp-listen-port <1024-65535>Configures the UDP port used to listen for incoming traffic
  • <1024-65535> – Specify the UDP port from 1024 - 65535 (default is 1701)
l2tpv3Configures L2TPv3 protocol settings for a profile
loggingEnables L2TPv3 tunnel event logging and debugging. When enabled, all events relating to Ethernet frames to and from bridge VLANs and physical ports on a specified IP address, host or router ID are logged. This option is disabled by default.
ip-address [<IP>|any]Configures the L2TPv3 peer tunnel IP address for which event logging is enabled. The options are:
  • <IP> – Specify the peer‘s IP address. L2TPv3 events are captured and logged for the specified peer.
  • any – Peer‘s IP address is not specified. Enables event logging for all incoming connections from any IP address.
hostname [<HOSTNAME>| any]Configures the L2TPv3 peer tunnel hostname for which event logging is enabled. The options are:
  • <HOSTNAME> – Specify the peer‘s host name. L2TPv3 events are captured and logged for specified host.
  • any – Peer‘s hostname is not specified. Enables debugging for all incoming connections from any host.
router-id [<IP>|<WORD>|any]Configures the L2TPv3 tunnel router ID for which event logging is enabled. The options are:
  • <IP> – Specify the router ID in the IP address format.
  • <WORD> – Specify the router ID in the form of an integer or range. For example 100-200.
  • any – Router ID is not specified. Enables debugging for all incoming connections from any L2TPv3 router.
nx9500-6C8809(config-profile-TestNX5500)#l2tpv3 hostname l2tpv3Host1
nx9500-6C8809(config-profile-TestNX5500)#l2tpv3 inter-tunnel-bridging
nx9500-6C8809(config-profile-TestNX5500)#show context
profile nx5500 TestNX5500
 bridge vlan 1
  bridging-mode isolated-tunnel
  ip igmp snooping
  ip igmp snooping querier
Related Commands
noNegates a L2TPv3 tunnel settings on this profile
