radius-user-pool-policy
Configures a RADIUS user pool policy and enters its configuration mode. A user pool defines policies for individual user access to the internal RADIUS resources. User pool policies define unique permissions (either temporary or permanent) that control user access to the local RADIUS resources. A pool can contain a single user or multiple users.
Use the (config) instance to configure RADIUS user pool policy commands. To navigate to the radius-user-pool-policy instance, use the following commands:
<DEVICE>(config)#radius-user-pool-policy <POOL-NAME>
nx9500-6C8809
(config)#radius-user-pool-policy testuser
nx9500-6C8809
(config-radius-user-pool-testuser)#?
Radius User Pool Mode commands:
  duration  Set a guest user's access duration
  no        Negate a command or set its defaults
  user      Radius user configuration
  clrscr    Clears the display screen
  commit    Commit all changes made in this session
  do        Run commands from Exec mode
  end       End current mode and change to EXEC mode
  exit      End current mode and down to previous mode
  help      Description of the interactive help system
  revert    Revert changes
  service   Service Commands
  show      Show running system information
  write     Write running configuration to memory or terminal
nx9500-6C8809
The following table summarizes RADIUS user pool policy configuration commands:
Table 1. RADIUS-User-Pool Config Mode Commands
CommandsDescription
durationModifies a guest user‘s duration of captive-portal access
userConfigures the RADIUS user parameters
noNegates a command or sets its default
