http-analyze
bridge
Enables the analysis of URLs and data traffic on this Bridge VLAN. When enabled, URLs and data are forwarded to the controller running the HTTP analytics engine.
Syntax
http-analyze {filter [images|post|query-string]}
Parameters
http-analyze filter [images|post| query-string]Enables URL and HTTP data analysis. Optionally use the filter keyword to filter out specific URLs
  • filter – Optional. Filters out specific URLs
    • images – Filters out URLs referring to images
    • post – Filters out URLs referring to POSTs
    • query-string – Filters out query strings received from URLs
rfs4000-229D58(config-device 00-23-68-22-9D-58-bridge-vlan-4)#http-analyze filter images
rfs4000-229D58(config-device 00-23-68-22-9D-58-bridge-vlan-4)#show context
 bridge vlan 4
Related Commands
noDisables forwarding of URLs and data to the controller running the HTTP analytics engine
