rssi-interval-duration
Configures the interval, in seconds, at which dedicated sensors scan channels for RSSI assessments and send the RSSI data obtained to a specified server resource
Syntax
rssi-interval-duration <1-60>
Parameters
rssi-interval-duration <1-60>Configures the RSSI interval duration in seconds. This is the interval at which the sensor scans channels for RSSI data and forwards the data to a dedicated server resource. The server calculates real-time locations of Wi-Fi devices based on the this data.
  • <1-60> – Specify the RSSI interval duration from 1 - 60 seconds. The default is 1 second.
The channels scanned for RSSI assessment depends on the scan-mode selected. For more information, see scan-mode and custom-scan.
Ensure that the server‘s IP address or hostname has been configured in the access point sensor‘s RF Domain context.
nx9500-6C8809(config-sensor-policy-test)#rssi-interval-duration 30
nx9500-6C8809(config-sensor-policy-test)#show context
sensor-policy test
 scan-mode Custom-Scan
 custom-scan channel-frequency 2412 width 20MHz scan-weight 1000
 custom-scan channel-frequency 2417 width 20MHz scan-weight 1000
Related Commands
no (sensor-policy-config-mode-commands)Resets the interval at which RSSI data is collected and sent by the sensor to the NSight server host to default (1 second)
