The following table summarizes the roaming-assist-policy configuration mode commands:
Command |
Description |
| action | Specifies the action to be invoked on the client |
| aggressiveness | Configures a roaming aggressiveness value for wireless clients |
| detection-threshold | Configure detection-threshold interval value |
| disassoc-time | Configures the disassociation interval |
| handoff-count | Configures the handoff-count value |
| handoff-threshold | Configures the handoff-threshold value |
| monitoring-interval | Configures the client monitoring interval |
| sampling interval | Configures the interval at which clients are sampled to determine their RSSI value |
| no | Removes or reverts this roaming assist policy settings based on the parameters passed |
For more information on common commands (clrscr, commit, help, revert, service, show, write, and exit), see Common Commands.
The input parameter <HOSTNAME>, wherever used in syntaxes across this chapter, cannot include an underscore (_) character. In other words, the name of a device cannot contain an underscore.Section contents:
