Creates a EX3500 QoS (Quality of Service) class map policy and enters its configuration mode
A QoS class map policy contains a set of DiffServ (Differentiated Services) classification criteria that are used to classify incoming traffic into different category and provide differentiated service based on this classification. Each policy defines a set match criteria rules that use objects, such as access lists, IP precedence or DSCP values, and VLANs. When configured and applied, the policy classifies traffic based on layer 2, layer 3, or layer 4 information contained in each incoming packet.
ex3500-qos-class-map-policy <POLICY-NAME>
| <POLICY-NAME> | Specify the EX3500 QoS class map policy name. If the policy does not exist, it is created. |
nx9500-6C8809(config)#ex3500-qos-class-map-policy dscp nx9500-6C8809(config-ex3500-qos-class-map-policy-dscp)#? EX3500_Qos_class_map Mode commands: description Class-map description match Defines the match criteria to classify traffic no Negate a command or set its defaults rename Redefines the name of class-map clrscr Clears the display screen commit Commit all changes made in this session do Run commands from Exec mode end End current mode and change to EXEC mode exit End current mode and down to previous mode help Description of the interactive help system revert Revert changes service Service Commands show Show running system information write Write running configuration to memory or terminal nx9500-6C8809(config-ex3500-qos-class-map-policy-dscp)#
| no | Removes an existing EX3500 QoS class map policy |
Section contents:
