Configures individual data rates for the 2.4 GHz, 5 GHZ, and 6 GHz frequency bands. In Mesh network, a mesh point is a virtual mesh networking instance on a device, similar to a WLAN AP. On each device, up to 4 mesh points can be created and 2 can be created per radio. Each mesh point radio can have carefully administrated radio rates specific to the 2.4 GHz, 5 GHZ, or 6 GHz band. Use this command to configure these radio rates.
Ensure that the basic data rates configured on a meshpoint‘s root and non-root access points is the same.data-rates [2.4GHz|5GHz|6GHz]
data-rates 2.4GHz [b-only|bg|bgn|default|g-only|gn]
data-rates 2.4GHz custom (1|11|12|18|2|24|36|48|5.5|54|6|9|basic-1|basic-11| basic-12|basic-18|basic-2|basic-24|basic-36|basic-48|basic-5.5|basic-54|basic-6|basic-9| mcs0-15|mcs0-7|mcs8-15|basic-mcs0-7)
data-rates 5GHz [a-only|an|default]
data-rates 5GHz custom (12|18|24|36|48|54|6|9|basic-1|basic-11|basic-12|basic-18| basic-2|basic-24|basic-36|basic-48|basic-5.5|basic-54|basic-6|basic-9|mcs0-15|mcs0-7|mcs8-15| basic-mcs0-7)
data-rates 6GHz (ax|default)
data-rates 6GHz custom {6|9|12|18|24|36|48|54|mcs0-7|mcs8-15|mcs0-15|basic-1|basic-2|
basic-5.5|basic-6|basic-9|basic-11|basic-12|basic-18|basic-24|basic-36|basic-48|basic-54|
basic-mcs0-7}
data-rates 2.4GHz | Configures preset data rates for the 2.4 GHz frequency. |
b-only |
Configures data rate for the meshpoint using 802.11b only rates. |
bg |
Configures data rate for the meshpoint using 802.11b and 802.11g rates. |
| bgn | Configures data rate for the meshpoint using 802.11b, 802.11g, and 802.11n rates |
default |
Configures data rate for the meshpoint at a pre-configured default rate for this frequency. |
g-only |
Configures data rate for the meshpoint using 802.11g only rates. |
gn |
Configures data rate for the meshpoint using 802.11g and 802.11n rates. |
data-rates 2.4GHz |
Configures the preset data rates for the 2.4 GHz frequency Define both minimum Basic and optimal Supported rates as required for the 802.11b rates, 802.11g rates and 802.11n rates supported by the 2.4 GHz band. These are the rates wireless client traffic is supported within this mesh point. These are the rates wireless client traffic is supported within this mesh point. If supporting 802.11n, select a supported MCS index. Set a MCS (Modulation and Coding Scheme) in respect to the radio's channel width and guard interval. A MCS defines (based on RF channel conditions) an optimal combination of 8 data rates, bonded channels, multiple spatial streams, different guard intervals and modulation types. Meshpoints can communicate as long as they support the same basic MCS (as well as non-802.11n basic rates). The selected rates apply to associated client traffic within this mesh point only. |
custom (1|11|12|18|2|24|36| 48|5.5|54|6|9|basic-1| basic-11|basic-12|basic-18|basic-2|basic-24|basic-36| basic-48|basic-5.5|basic-54|basic-6|basic-9|mcs0-15| mcs0-7|mcs8-15| basic-mcs0-7) |
Configures custom rates
Multiple choices can be made from the above list of rates |
data-rates 5GHz |
Configures the preset data rates for the 5.0 GHz frequency |
a-only |
Configures the data rate for the meshpoint using 802.11a only rates |
bn |
Configures the data rate for the meshpoint using 802.11a and 802.11n rates |
default |
Configures the data rate for the meshpoint at a pre-configured default rate for this frequency |
g-only |
Configures the data rate for the meshpoint using 802.11g only rates |
gn |
Configures the data rate for the meshpoint using 802.11g and 802.11n rates |
data-rates 5GHz |
Configures the preset data rates for the 5.0 GHz frequency Define both minimum Basic and optimal Supported rates as required for 802.11a and 802.11n rates supported by the 5.0 GHz radio band. These are the rates wireless client traffic is supported within this mesh point. If supporting 802.11n, select a supported MCS index. Set a MCS in respect to the radio's channel width and guard interval. A MCS defines (based on RF channel conditions) an optimal combination of 8 data rates, bonded channels, multiple spatial streams, different guard intervals and modulation types. Mesh points can communicate as long as they support the same basic MCS (as well as non-802.11n basic rates). The selected rates apply to associated client traffic within this mesh point only. |
custom (12|18|24|36|48|54| 6|9|basic-1|basic-11| basic-12|basic-18|basic-2| basic-24|basic-36|basic-48| basic-5.5|basic-54|basic-6|basic-9|mcs0-15|mcs0-7| mcs8-15|basic-mcs0-7) |
Multiple choices can be made from the above list of rates. |
| data-rates 6GHz | Configures the preset data rates for the 6.0 GHz frequency |
ax |
Configures the data rate for the meshpoint using 802.11ax rates |
default |
basic-mcs0-7}
data-rates 6GHz custom |
Customized configuration of the data rates for the 6.0 GHz frequency at the specified basic range or mcs index. |
nx9500-6C8809(config-meshpoint-test)#data-rates 2.4GHz bgn
nx9500-6C8809(config-meshpoint-test)#data-rates 5GHz an
nx9500-6C8809(config-meshpoint-test)#show context meshpoint test meshid test beacon-format mesh-point control-vlan 25 allowed-vlans 1,10-16,18-23 data-rates 2.4GHz bgn data-rates 5GHz an security-mode none no root nx9500-6C8809(config-meshpoint-test)#
| no (meshpoint-config) |
Resets data rates for each frequency band for this meshpoint |
