Enables ACS (Automatic Channel Selection) on this meshpoint device (access point). When enabled, this feature automatically selects the best channel for a meshpoint-device radio based on the device configuration, channel conditions, and network layout.
In a wireless network deployment, it is advantageous for network devices to have the ability to operate in multiple channels and not be limited to only a single channel. Multiple channels increase the bandwidth and throughput of the wireless network. In such a scenario, each network device must have a mechanism to dynamically select a suitable channel of operation. ACS provides the required mechanism for a MCX enabled device.
Use this command to configure the ACS settings and override the default meshpoint configurations.
Access Points — AP 6522, AP 6532, AP 6562, AP 7161, AP 7502, AP-7522, AP 7532, AP-7562, AP7632, AP7662, AP-8432, AP8533
acs [channel-hold-time|channel-switch-delta|channel-width|ocs-duration|ocs-frequency| path-min|path-threshold|preferred-interface-tolerance-period|preferred-radio-interface| priority-meshpoint|sample-count|snr-delta|signal-threshold|tolerance-period]
acs channel-hold-time [2.4GHz|5GHz|6GHz] <0-86400>
acs channel-switch-delta [2.4GHz|5GHz|6GHz] <5-35>
acs channel-width [2.4GHz|5GHz|6GHz] [20MHz|40MHz|80MHz|160MHz|auto]
acs ocs-duration [2.4GHz|5GHz|6GHz] <20-250>
acs ocs-frequency [2.4GHz|5GHz|6GHz] <1-60>
acs path-min [2.4GHz|5GHz|6GHz] <100-20000>
acs path-threshold [2.4GHz|5GHz|6GHz] <800-65535>
acs preferred-interface-tolerance-period [2.4GHz|5GHz|6GHz] <10-600>
acs preferred-radio-interface [2.4GHz|5GHz|6GHz] <0-2>
acs priority-meshpoint [2.4GHz|5GHz|6GHz] <MESHPOINT-NAME>
acs sample-count [2.4GHz|5GHz|6GHz] <1-10>
acs snr-delta [2.4GHz|5GHz|6GHz] <1-100>
acs signal-threshold [2.4GHz|5GHz|6GHz] <-100-0>
acs tolerance-period [2.4GHz|5GHz|6GHz] <10-600>
acs |
Configures ACS settings and overrides on the selected meshpoint-device |
channel-hold-time [2.4GHz|5GHz|6GHz] <0-86400> |
Configures the minimum time, in seconds, before a periodic scan, to assess channel conditions for a meshpoint root, is triggered.
The following keyword is common to the 2.4 GHz, 5.0 GHz, and 6.0 GHz bands:
Note: A value of ‘0‘ disables periodic channel assessment.
acs |
channel-switch-delta [2.4GHz|5GHz|6GHz] <5-35> |
Configures the difference in interference between the current and best channel needed to trigger a channel change. Once the difference in the current channel and the best channel interference equals the configured value, a channel change is triggered.
acs |
| channel-width [2.4GHz|5GHz|6GHz] [20MHz|40MHz|80MHz| auto] |
Configures the channel width that meshpoint auto channel selection assigns to the radio
The following keywords are common to the 2.4 GHz, 5.0 GHz, 6.0 GHz bands:
acs |
ocs-duration [2.4GHz|5GHz|6GHz] <20-250> |
Configures the duration, in milliseconds, of OCSs (off -channel scans)
acs |
ocs-frequency [2.4GHz|5GHz|6GHz] <1-60> |
Configures the interval, in seconds, at which off-channel scan is performed. An ocs-frequency of 10 seconds means that an off-channel scan will be performed once every 10 seconds.
acs |
path-min [2.4GHz|5GHz|6GHz] <100-20000> |
Configures the minimum root path metric needed for auto channel selection. This is the acceptance root path metric value to consider a root as a possible candidate mesh node.
acs |
path-threshold [2.4GHz|5GHz|6GHz] <800-65535> |
Configures the root path metric threshold for auto channel selection. This is the acceptance root path metric threshold beyond which the root bound to is considered as bad.
The following keyword is common to the ‘2.4 GHz‘ and ‘5.0 GHz‘ bands:
| acs | Configures ACS settings and overrides on the selected meshpoint-device |
| preferred-interface-tolerance-period [2.4GHz|5GHz|6GHz] <10-600> | Configures the maximum tolerance period, in seconds, for low root metrics on the preferred interface. This is the duration to wait before triggering an automatic channel selection for the next mesh-hop on the preferred interface.
| preferred-radio-interface [2.4GHz|5GHz|6GHz] <0-2> | Configures the preferred radio interface on dual band APs
acs |
priority-meshpoint [2.4GHz|5GHz|6GHz] <MESHPOINT-NAME> |
Configures the priority meshpoint. Configuring a priority meshpoint overrides automatic meshpoint configuration.
acs |
sample-count [2.4GHz|5GHz|6GHz] <1-10> |
Configures the minimum number of scan cycle samples to consider for auto channel selection
acs |
snr-delta [2.4GHz|5GHz|6GHz] <1-100> |
Configures the channel SNR delta. A meshpoint on a candidate channel must have a SNR of a greater delta than the next hop on the current channel.
acs snr-threshold [2.4GHz|5GHz|6GHz] <-100-0>
acs |
snr-threshold [2.4GHz|5GHz|6GHz] <-100-0> |
Configures the signal strength threshold. If the signal strength of the next hop drops below the configured snr-threshold, a scan is triggered.
acs |
Configures the maximum tolerance period in seconds. This is the interval to wait for the root bound to recovery from a bad link.
The following keyword is common to the ‘2.4 GHz, 5.0 GHz, and 6.0 GHz bands:
rfs4000-229D58(config-profile-testAP71XX-meshpoint-test)#acs channel-hold-time 2.4GHz 2500
rfs4000-229D58(config-profile-testAP71XX-meshpoint-test)#acs ocs-duration 2.4GHz 30
rfs4000-229D58(config-profile-testAP71XX-meshpoint-test)#acs ocs-frequency 2.4GHz 1
rfs4000-229D58(config-profile-testAP71XX-meshpoint-test)#show context meshpoint-device test acs ocs-frequency 2.4GHz 1 acs osc-duration 2.4GHz 30 acs channel-hold-time 2.4GHz 2500 rfs4000-229D58(config-profile-testAP71XX-meshpoint-test)#
| no (meshpoint-device-config) |
Reverts the configured ACS settings to default |
