wing-extensions [ap-attributes-information {include-hostname}|
coverage-hole-detection {11k-clients|offset <5-20>|threshold <-80--60}|
ft-over-ds-aggregate|move-command|scan-assist {channel-info-interval <6-9>}|
smart-scan|wing-load-information|wmm-load-information]
| wing-extensions | Enables support for inclusion of ExtremeWireless WiNG-specific client extensions in radio transmissions |
| ap-attributes-information {include-hostname} | Enables support for AP attributes IE (information element)
AP attributes IE is not added to beacons and probe responses by default. |
| overage-hole-detection {11k-clients| offset <5-20>| threshold <-80--60>} | Enables coverage hole detection (CHD) and configures CHD parameters. When enabled, allows clients (MUs) to inform an access point when it experiences a coverage hole. A coverage hole is an area of poor wireless coverage not supported by a ExtremeWireless WiNG managed access point radio. Enable radio resource measurement prior to enabling CHD. For enabling radio resource measurement, see radio-resource-measurement. CHD is disabled by default. After enabling CHD, optionally configure the following parameters:
| ft-over-ds-aggregate | Enables fast-transition (FT) aggregation of action frames. When enabled, increases roaming speed by eliminating separate key exchange handshake frames with potential roam candidates. Enable fast transition to complete an initial FT over distribution system (DS) handshake with multiple roam candidates (up to 6) at once, eliminating the need to send separate FT over DS handshakes to each roam candidate. This option is disabled by default. |
| move-command | Enables use of Hyper Fast Secure Roaming (HFSR) for clients on this WLAN. This feature applies only to certain client devices. This option is disabled by default. |
| scan-assist {channel-info-interval <6-9>} | Enables support for scanning assist. When enabled, allows faster roams on Dynamic Frequency Selection (DFS) channels by eliminating passive scans. Clients get channel information directly from possible roam candidates. This option is disabled by default.
| smart-scan | Enables a smart scan to refine a clients channel scans to just a few channels as opposed to all available channels. This option is disabled by default. |
| wing-load-information | Enables support for the ExtremeWireless WiNG load information element (Element ID 173) with legacy Symbol Technology clients, thus making them optimally interoperable with the latest Extreme Networks access points. This option is enabled by default. |
| wmm-load-information | Enables support for ExtremeWireless WiNG Wi-Fi MultiMedia (WMM) Load Information Element in radio transmissions with legacy clients. This option is disabled by default. |
nx9500-6C8809(config-wlan-test)#wing-extensions wmm-load-information
nx9500-6C8809(config-wlan-test)#show context wlan test description TestWLAN ssid test bridging-mode local encryption-type tkip-ccmp authentication-type eap kerberos server timeout 12 kerberos server primary host 172.16.10.2 accounting syslog host 172.16.10.4 port 2 data-rates 2.4GHz gn wing-extensions wmm-load-information client-load-balancing probe-req-intvl 5ghz 5 --More-- nx9500-6C8809(config-wlan-test)#
| no (wlan-config-mode) | Disables support for ExtremeWireless WiNG-specific client extensions to the IEEE 802.11x WLAN standards. Use the keywords provided to disable a specific wing-extension. |
