proxy-nd-mode
Configures the proxy ND mode for this WLAN member clients as either strict or dynamic. ND proxy is used in IPv6 to provide reachability by allowing a client to act as proxy. Proxy certificate signing can be done either dynamically (requiring exchanges of identity and authorization information) or statically when the network topology is defined.
Syntax
proxy-nd-mode [dynamic|strict]
Parameters
proxy-nd-mode [dynamic|strict]Configures the proxy ND mode for this WLAN member clients. The options are: dynamic and strict
  • dynamic – Forwards ND request to wireless for which a response could not be proxied. This is the default value.
  • strict – Does not forward ND requests to the wireless side
nx9500-6C8809(config-wlan-test)#proxy-nd-mode strict
nx9500-6C8809(config-wlan-test)#show context
wlan test
 ssid test
 bridging-mode tunnel
 encryption-type none
 authentication-type none
 wpa-wpa2 server-only-authentication
 opendns device-id 44-55-66
Related Commands
no (wlan-config-mode)Reverts the proxy ND mode to default (dynamic)
