channel-group
interface-config-ge-instance
Assigns this Ethernet port to a channel group. Ethernet ports can be aggregated to form a channel group. They can be aggregated to form a minimum of one and maximum of two channel groups. A port can be a member of only one channel group at a time.
Syntax
channel-group <1-4>
Parameters
channel-group <1-4>
<1-4>Specifies a channel group number from 1 - 4. The number of channel groups supported varies with the device type. For example:
  • NX5500 – Supports three channel groups
  • NX75XX – Supports four channel groups
  • NX95XX – Supports two channel groups
nx9500-6C8809(config-profile-testnx5500-if-ge1)#channel-group 1
nx9500-6C8809(config-profile-testnx5500-if-ge1)#show context
 interface ge1
  ip dhcp trust
  qos trust dscp
  qos trust 802.1p
  channel-group 1
Related Commands
noRemoves the channel group to which this port belongs
