AP560i is a cloud-ready, stadium optimized, WiFi 6, 802.11ax outdoor access point with two internal antenna. It is ideally suited for high-density user environments, such as stadiums, large public venues, convention centers and school auditoriums. The AP560i offers flexible deployment options and can be mounted under a seat, to a pole, and a wall, thereby ensuring exceptional mobile user experience.
Radios: 2 radios; 1 IoT radio (2.4 GHz).
Console Port: RJ45.
Two Ethernet Ports:
GE1 - 10/100/1000/2500/5000 Mbps auto-negotiation Ethernet port, RJ45, with PoE In
GE2 - 10/100/1000 Mbps auto-negotiation Ethernet port, RJ45, with PoE In
LEDs: 2 – All LEDs will be on during reset
One Reset button
Power: PoE 802.3at; 12VDC external power in connector
