no
Device Config Commands
Negates a command or resets values to their default
Syntax
no [adopter-auto-provisioning-policy-lookup|adoption-site|alias|application-policy|area|arp|auto-learn-staging-config|autoinstall|bridge|captive-portal| cdp|channel-list|cluster|configuration-persistence|contact|controller| country-code|critical-resource|crypto|database-backup|device-upgrade|dot1x| dpi|dscp-mapping|email-notification|environmental-sensor|events|export| file-sync|floor|geo-coordinates|gre|hostname|http-analyze|interface|ip|ipv6| l2tpv3|l3-lite-table|lacp|layout-coordinates|led|led-timeout| legacy-auto-downgrade|legacy-auto-update|license|lldp|load-balancing|location| logging|mac-address-table|mac-auth|mac-name|management-server|memory-profile| meshpoint-device|meshpoint-monitor-interval|min-misconfiguration-recovery-time| mint|mirror|misconfiguration-recovery-time|mpact-server|noc|nsight||ntp| offline-duration|override-wlan|power-config|preferred-controller-group| preferred-tunnel-controller|radius|raid|rf-domain-manager|router|rsa-key| sensor-server|slot|spanning-tree|timezone|traffic-class-mapping|traffic-shape| trustpoint|tunnel-controller|use|vrrp|vrrp-state-check|wep-shared-key-auth| service]
Parameters
no <PARAMETERS>
no <PARAMETERS>Removes or resets the logged device‘s settings based on the parameters passed
Usage Guidelines
The no command negates any command associated with it. Wherever required, use the same parameters associated with the command getting negated
ap505-13403B(config-device-94-9B-2C-13-40-38)#no area
ap505-13403B(config-device-94-9B-2C-13-40-38)#no contact
