Associates a device‘s autogen-uniqueid with this crypto CMP policy
A device‘s autogen-uniqueid is a combination of a user-defined string (prefix or suffix) and a substitution token. The WiNG software implementation provides two built-in substitution tokens: $SN and $MiNT-ID that represent the device‘s serial number and MiNT ID respectively. These substitution tokens are internally retrieved and combined with the user-defined string to auto generate a unique identity for a device.
To auto generate the device‘s unique ID, in the device configuration mode execute the following command:
autogen-uniqueid <WORD>
For more information on the autogen-uniqueid command, see autogen-uniqueid.
use autogen-uniqueid
use autogen-uniqueid | Associates a device‘s autogen-uniqueid with this crypto CMP policy. The device‘s autogen-uniqueid should be existing and configured. |
ap6522-D8273A(config-cmp-policy-CMP)#use autogen-uniqueid
ap6522-D8273A(config-cmp-policy-CMP)#show context crypto-cmp-policy CMP cert-update cert-renewal-timeout 60 use autogen-uniqueid ca-server primary host 192.168.8.74 port 8 path cmp trustpoint cmp-test subject-name "CN=ExampleCompany, O=Example Company" secret 0 test-secret reference-id 123456 sender-name "CN=ExampleCompany.com, O=Example Company" recipient-name "O=Example Company, CN=ExampleCompany.com" subjectAltName dn TechPubsCA ap6522-D8273A(config-cmp-policy-CMP)#
| no | Removes the device‘s autogen-uniqueid associated with this crypto CMP policy |
