speed
interface-config-ge-instance
Specifies the speed of a FastEthernet (10/100) or GigabitEthernet (10/100/1000) port. This is the speed at which the port can receive and transmit the data.
Syntax
speed [10|100|1000|auto]
Parameters
10Forces 10 Mbps operation
100Forces 100 Mbps operation
1000Forces 1000 Mbps operation
autoPort automatically detects its operational speed based on the port at the other end of the link. Select this option to enable the port to automatically exchange information about data transmission speed and duplex capabilities. Auto negotiation is helpful when in an environment where different devices are connected and disconnected on a regular basis.
Usage Guidelines
Set the interface speed to auto detect and use the fastest speed available. Speed detection is based on connected network hardware.
nx9500-6C8809(config-profile-testnx5500-if-ge1)#speed 10
nx9500-6C8809(config-profile-testnx5500-if-ge1)#show context
 interface ge1
  description "This is GigabitEthernet interface for Royal King"
  speed 10
  duplex full
  spanning-tree bpduguard enable
  spanning-tree bpdufilter disable
  spanning-tree force-version 1
  spanning-tree guard root
  spanning-tree mst 2 port-priority 10
  dot1x supplicant username Bob password 0 test@123
  ip dhcp trust
  ip arp header-mismatch-validation
  qos trust dscp
  qos trust 802.1p
  channel-group 1
Related Commands
noResets speed to default (auto)
