Enables
non-unicast frame forwarding on this radio. Once enabled, select one of the
available options to specify whether these frames should always follow DTIM,
or only follow DTIM when using power save aware mode.
follow-dtim
Specifies frames
always wait for the DTIM interval to time out. The DTIM interval is
configured using the beacon command. This is the default setting.
power-save-aware
Enables
immediate forwarding of frames only if all associated wireless clients are
in the power save mode
non-unicast queue [<1-200>|bss <1-16> <1-200>]
non-unicast
queue
Enables
non-unicast frame forwarding on this radio. Once enabled, specify the number
of broadcast packets queued per BSS on this radio. This option is enabled by
default.
This command also
enables you to override the default on a specific BSS.
<1-200>
Specify a number
from 1 - 200. This value applies to all BSSs. The default is 50 frames per
BSS.
bss <1-16>
<1-200>
Overrides the
default on a specified BSS
<1-16> – Select the
BSS number from 1 - 16.
<1-200> –
Specify the number of broadcast packets queued for the selected
BSS from 1 - 200.
Enables
non-unicast frame forwarding on this radio. Once enabled, use one of the
available options to configure the rate at which these frames are
transmitted.
bss
<1-16>
Overrides the
<1-16> – Select the
BSS number from 1 - 16. The transmit rate selected is applied only to
the BSS specified here. The tx-rate options are: dynamic-all,
dynamic-basic, highest-basic, lowest-basic.
dynamic-all
Dynamically
selects a rate from all supported rates based on current traffic
conditions
dynamic-basic
Dynamically
selects a rate from all supported basic rates based on current traffic
conditions
highest-basic
Uses the highest
configured basic rate. This is the default setting.
