Displays specified system component
settings. There are a number of ways to invoke the show command.
When invoked without any arguments,
it displays information about the current context. If the current context contains
instances, the show command (usually) displays a list of these instances.
When invoked with the display
parameter, it displays information about that component.
The show command displays configuration details based on the
configuration mode, in which the command is executed, and the parameters
passed. For example, when executed in the AAA policy configuration mode, it
displays the logged AAA policy‘s current settings. The example below shows
the configuration details that can be viewed in the Priv Executable
mode.
nx9500-6C8809#show ?
adoption Adoption related information
bluetooth Bluetooth Configuration/Statistics commands
bonjour Bonjour Gateway related commands
boot Display boot configuration.
captive-portal Captive portal commands
captive-portal-page-upload Captive portal internal and advanced page upload
cdp Cisco Discovery Protocol
classify-url Query the category of an URL
clock Display system clock
cluster Cluster Protocol
cmp-factory-certs Display the CMP certificate status
commands Show command lists
context Information about current context
critical-resources Critical Resources
crypto Encryption related commands
database Database
debug Debugging functions
debugging Debugging functions
device-upgrade Device Upgrade
dot1x 802.1X
dpi Deep Packet Inspection
eguest Registration EGuest process
environmental-sensor Display Environmental Sensor Module status
event-history Display event history
event-system-policy Display event system policy
ex3500 EX3500 device details
extdev External device (T5, Ex3500..)
file Display filesystem information
file-sync File sync between controller and adoptees
firewall Wireless Firewall
global Global-level information
gre Show l2gre tunnel info
guest-notification-config Show guest-notification information
guest-registration Guest registration commands
interface Interface Configuration/Statistics commands
ip Internet Protocol (IP)
ip-access-list IP ACL
ipv6 Internet Protocol version 6 (IPv6)
ipv6-access-list IPV6 ACL
l2tpv3 L2TPv3 information
lacp LACP commands
ldap-agent LDAP Agent Configuration
licenses Show installed licenses and usage
lldp Link Layer Discovery Protocol
logging Show logging information
mac-access-list MAC ACL
mac-address-table Display MAC address table
mac-auth MAC authentication
mac-auth-clients MAC authenticated clients
mint MiNT protocol
mirroring Show mirroring sessions
nsight Nsight Server Module
ntp Network time protocol
password-encryption Pasword encryption
pppoe-client PPP Over Ethernet client
privilege Show current privilege level
radius RADIUS statistics commands
raid Show RAID status
reload Scheduled reload information
remote-debug Show details of remote debug sessions
rf-domain-manager Show RF Domain Manager selection details
role Role based firewall
route-maps Display Route Map Statistics
rtls RTLS Statistics
running-config Current operating configuration
session-changes Configuration changes made in this session
session-config This session configuration
sessions Display sessions
site-config-diff Difference between site configuration on the NOC
and actual site configuration
slot Expansion slots stats
smart-rf Smart-RF Management Commands
spanning-tree Display spanning tree information
startup-config Startup configuration
t5 Display T5 inventory information
terminal Display terminal configuration parameters
timezone The timezone
traffic-shape Display traffic shaping
upgrade-status Display last image upgrade status
version Display software & hardware version
virtual-machine Virtual Machine
vrrp VRRP protocol
web-filter Web filter
what Perform global search
wireless Wireless commands
wwan Display wireless WAN Status
nx9500-6C8809#
For more information on the show
command, see show-commands.
