simultaneous-users
Specifies the number of users (client MAC addresses) that can simultaneously log on to the captive portal. This option is disabled by default.
Syntax
simultaneous-users <1-8192>
Parameters
Specifies the number of MAC addresses that can simultaneously access the captive portal
  • <1-8192> — Select a number in the range 1–8192.
nx9500-6C8809(config-captive-portal-test)#simultaneous-users 5
nx9500-6C8809(config-captive-portal-test)#show context
captive-portal test
 access-time 35
 custom-auth info bob bob@examplecompany.com
 connection-mode https
 inactivity-timeout 750
 server host 172.16.10.9
Related Commands
no
Resets or disables captive portal commands
