client-identity
Associates an existing and configured client identity (device fingerprinting definition) with this client identity group
Syntax
client-identity <CLIENT-IDENTITY-NAME> precedence <1-10000>
Parameters
client-identity <CLIENT-IDENTITY-NAME>Associates a client identity with this group
  • <CLIENT-IDENTITY-NAME> – Specify a client identity name (should be existing and configured)
precedence <1-10000>Determines the order in which client identity is used.
  • <1-10000> – Specify this client identity precedence from <1-10000>.
The client identity rule is applied based on its precedence value. Lower the value, higher is the precedence. Therefore, a client identity with precedence 5 gets priority over a client identity having precedence 20.
The following example shows two client identities created and configured:
nx9500-6C8809(config)#show context
! Configuration of NX9500 version 7.1.0.0-010D
version 2.6
client-identity TestClientIdentity
 dhcp 1 message-type request option-codes exact hexstring 5e4d36780b3a7f
client-identity test
 dhcp 2 message-type discover option 2 exact hexstring 012456c22c44
 dhcp 1 message-type request option 60 exact ascii MSFT5.0
 dhcp-match-message-type all
client-identity-group ClientIdentityGroup
 client-identity TestClientIdentity precedence 1
client-identity-group test
ip access-list BROADCAST-MULTICAST-CONTROL
 permit tcp any any rule-precedence 10 rule-description "permit all TCP traffic"
 --More--
The following example associates client identity ‘test‘ with the client identity group ‘test‘:
nx9500-6C8809(config-client-identity-group-test)#client-identity test precedence 1
The following example shows the client identity group ‘test‘ with two associated client identities having precedence 1 and 2:
nx9500-6C8809(config-client-identity-group-test)#client-identity TestClientIdentity precedence 2
nx9500-6C8809(config-client-identity-group-test)#show context
Related Commands
no Removes the client identity associated with the client identity group
