mu-mimo
interface-config-radio-instance
Enables multi-user multiple input multiple output (MU-MIMO) support on the selected radio. When enabled, multiple users are able to simultaneously access the same channel using the spatial degrees of freedom offered by MIMO.
Syntax
mu-mimo
Parameters
None
nx9500-6C8809(config-profile-TestAP510-if-radio1)#mu-mimo
nx9500-6C8809(config-profile-TestAP510-if-radio1)#show context include-factory | include mu-mimo
  mu-mimo
ap510-80C2AC(config-device-84-24-8D-80-C2-AC-if-radio1)#mu-mimo
pa510-80C2AC(config-device-84-24-8D-80-C2-AC-if-radio1)#show context include-factory | include mu-mimo
  mu-mimo
Related Commands
no (radio-interface-config-command)Disables mu-mimo on the selected radio
