| Command | Description |
| area | Specifies OSPF enabled interfaces |
| auto-cost | Specifies the reference bandwidth in terms of Mbits per second |
| default-information | Controls the distribution of default information |
| ip | Configures IP nternet Protocol) default gateway priority |
| network | Defines OSPF network settings |
| ospf | Enables OSPF |
| passive | Specifies the configured OSPF interface as passive interface |
| redistribute | Specifies the route types redistributed by OSPF |
| route-limit | Specifies the limit for the number of routes managed by OSPF |
| router-id | Specifies the router ID for OSPF |
| no (router-mode-config-command) | Negates a command or sets its defaults |
For information on common commands (clrscr, commit, help, revert, service, show, write, and exit), see Common Commands.
The input parameter <HOSTNAME>, wherever used in syntaxes across this chapter, cannot include an underscore (_) character. In other words, the name of a device cannot contain an underscore.Section contents:
