mint
Displays MiNT protocol related statistics and configuration
Syntax
show mint [config|dis|id|info|known-adopters|links|lsp|lsp-db|mlcp|neighbors|route|
 stats|tunnel-controller|tunneled-vlans]
show mint [config|id|info|known-adopters|route|stats|tunneled-vlans]
{on <DEVICE-NAME>}
show mint [dis|links|neighbors|tunnel-controller] {details} {(on <DEVICE-NAME>)}
show mint lsp
show mint lsp-db {details <MINT-ADDRESS>} {(on <DEVICE-NAME>)}
show mint mlcp {history} {(on <DEVICE-NAME>)}
Parameters
show mint [config|id|info|known-adopters|route|stats|tunneled-vlans] {on <DEVICE-NAME>}
mintDisplays MiNT protocol information based on the parameters passed
configDisplays MiNT configuration
idDisplays local MiNT ID
infoDisplays MiNT status
known-adoptersDisplays known, possible, or reachable adopters
routeDisplays MiNT route table details
statsDisplays MiNT related statistics
tunneled-vlansDisplays MiNT tunneled VLAN details
on <DEVICE-NAME>The following keywords are common to all of the above parameters:
  • on <DEVICE-NAME> – Optional. Displays MiNT protocol details on a specified device
    • <DEVICE-NAME> – Specify the name of the AP, wireless controller, or service platform.
disDisplays MiNT network Designated Intermediate Systems (DISes) and Ethernet Virtualization Interconnects (EVISes)
linksDisplays MiNT networking link details
neighborsDisplays adjacent MiNT peer details
tunnel-controllerDisplays details of MiNT VLAN network tunnel wireless controllers for extended VLAN load balancing
details {(on <DEVICE-NAME>)}The following keywords are common to the ‘dis', ‘links', ‘neighbors', and ‘tunnel-controller' parameters:
  • details – Optional. Displays detailed MiNT information
    • on <DEVICE-NAME> – Optional. This is a recursive parameter, which displays MiNT information on a specified device
show mint lsp
lspDisplays this router's MiNT Label Switched Paths (LSPs)
lsp-dbDisplays MiNT LSP database entries
details <MINT_ADDRESS>Optional. Displays detailed MiNT LSP database entries
  • <MINT_ADDRESS> – Specify the MiNT address in the AA.BB.CC.DD format.
on <DEVICE-NAME>The following keyword is recursive and common to the ‘details' parameter:
  • on <DEVICE-NAME> – Optional. Displays MiNT LSP database entries on a specified device
This command displays the ‘hello-interval‘ and ‘hold-time‘ default values for both IP and VLAN links.
mlcpDisplays MiNT Link Creation Protocol (MLCP) status
historyOptional. Displays MLCP client history
on <DEVICE-NAME>The following keyword is recursive and common to the ‘history' parameter:
  • on <DEVICE-NAME> – Optional. Displays MLCP client history on a specified device
NOC-NX9500#show mint stats
2 Level-1 neighbors
Level-1 LSP DB size 5 LSPs (1 KB)
Last Level-1 SPFs took 0.000s
Level-1 SPF (re)calculated 6 times.
5 Level-1 paths.
0 Level-2 neighbors
Level-2 LSP DB size 0 LSPs (0 KB)
Last Level-2 SPFs took 0.000s
Level-2 SPF (re)calculated 0 times.
0 Level-2 paths.
NOC-NX9500#
NOC-NX9500#show mint lsp
id 19.6C.88.09, level 1, 2 adjacencies, 0 extended-vlans
seqnum 1519955, expires in 22 minutes, republish in 774 seconds
90 bytes, can-adopt: True, adopted-by: 00.00.00.00, dis-priority 5, Level-2-gateway: False
hostname "NOC-NX9500"
rf-domain "default", priority vector: 0xe0dc0000
adjacent to 70.38.06.49, cost 100
adjacent to 19.6D.B5.D4, cost 100
NOC-NX9500#
NOC-NX9500#show mint lsp-db
5 LSPs in LSP-db of 19.6C.88.09:
LSP 19.6C.88.09 at level 1, hostname "NOC-NX9500", 2 adjacencies, seqnum 1519955
LSP 19.6D.B5.D4 at level 1, hostname "SITE2-VLAN192", 2 adjacencies, seqnum 1972642
LSP 19.74.B4.5C at level 1, hostname "ap8132-74B45C", 1 adjacencies, seqnum 1742227
LSP 4D.83.30.A4 at level 1, hostname "ap7522-8330A4", 1 adjacencies, seqnum 519924
LSP 70.38.06.49 at level 1, hostname "SITE1-VLAN20", 2 adjacencies, seqnum 1391030
NOC-NX9500#
NOC-NX9500#show mint route
Destination : Next-Hop(s)
19.6D.B5.D4 : 19.6D.B5.D4 via ip-192.168.13.2:24576
19.74.B4.5C : 19.6D.B5.D4 via ip-192.168.13.2:24576
19.6C.88.09 : 19.6C.88.09 via self
70.38.06.49 : 70.38.06.49 via ip-20.168.10.2:24576
4D.83.30.A4 : 70.38.06.49 via ip-20.168.10.2:24576
NOC-NX9500#
NOC-NX9500#show mint config
Base priority 5
DIS priority 5
Control priority 220
UDP/IP Mint encapsulation port 24576
Global Mint MTU 1500
NOC-NX9500#
NOC-NX9500#show mint mlcp
MLCP VLAN state: MLCP_INIT
MLCP VLAN Hello Interval: 4s(default), Adjacency hold time: 13s(default)
  Potential VLAN links:  None
  All VLANs were scanned 1 times
MLCP IP: ENABLED
MLCP IPv6: ENABLED
MLCP IP/IPv6 state: MLCP_INIT
MLCP IP Hello Interval: 15s(default), Adjacency hold time: 46s(default)
  Potential L3 Links:
   None
NOC-NX9500#
