This chapter summarizes the crypto certificate management protocol (CMP) policy commands in the CLI command structure.
CMP is an Internet protocol designed to enable devices (access point, wireless controller, or service platform) to obtain and manage digital certificates in a Public Key Infrastructure (PKI) network. A Certificate Authority (CA) issues the certificates using the defined CMP.
WiNG CMP implementation allows you to configure a crypto CMP policy that enables auto installation and auto management of device certificates. When configured and implemented on a device, the crypto CMP policy allows the device to automatically trigger a certification request to a configured, CMP supported CA server. Once the certificate is validated and confirmed from the CA server it is saved on the device and becomes part of the trustpoint. During the creation of the CMP policy the trustpoint is assigned a name and client information. You can use a manually created trustpoint for one service (like HTTPS) and use the CMP generated trustpoint for RADIUS EAP certificate based authentication.
Use the (config) instance to configure a crypto CMP policy. To navigate to the crypto CMP policy configuration instance, use the following commands:
<DEVICE>(config)#crypto-cmp-policy <CRYPTO-CMP-POLICY-NAME>
nx9500-6C8809(config)#crypto-cmp-policy CMPPolicy nx9500-6C8809(config-cmp-policy-CMPPolicy)#? CMP Policy Mode commands: ca-server CMP CA Server configuration commands cert-key-size Set key size for certificate request cert-renewal-timeout Trigger a cert renewal request on timeout cross-cert-validate Validate cross-cert using factory-cert hash-algorithm Set hash algorithm for certificate request no Negate a command or set its defaults subjectAltName Configure subjectAltName value trustpoint Trustpoint for CMP use Set setting to use clrscr Clears the display screen commit Commit all changes made in this session do Run commands from Exec mode end End current mode and change to EXEC mode exit End current mode and down to previous mode help Description of the interactive help system revert Revert changes service Service Commands show Show running system information write Write running configuration to memory or terminal nx9500-6C8809(config-cmp-policy-CMPPolicy)#
This chapter is organized as follows:
Section contents:
