address [<IP>|<HOST-ALIAS-NAME>|range]
address [<IP>|<HOST-ALIAS-NAME>|range [<START-IP>|<START-HOST-ALIAS-NAME>] [<END-IP>|<END-HOST-ALIAS-NAME>]]
{class <DHCP-CLASS-NAME>}
<IP> |
Adds a single IP address to the DHCP address pool |
<HOST-ALIAS-NAME> |
Adds a single host mapped to the specified host alias. The host alias should be existing and configured. Note: A network host alias maps a name to a single network host. For example, ‘alias host $HOST 1.1.1.100‘. In this example the host alias is ‘$HOST‘ and it maps to a single host ‘1.1.1.100‘. For more information, see alias .
| range [<START-IP>| <START-HOST-ALIAS-NAME>] [<END-IP>|<END-HOST-ALIAS-NAME>] |
Adds a range of IP addresses to the DHCP address pool. Use one of the following options to provide the first IP address in the range:
Use one of the following options to provide the last IP address in the range:
Note: The host aliases should be existing and configured.
class <DHCP-CLASS-NAME> |
Optional. Applies additional DHCP options, or a modified set of options to those available to wireless clients. For more information, see dhcp-class (dhcpv4-server-policy-config).
rfs4000-229D58(config-dhcp-policy-test-pool-testPool)#address 192.168.13.4 class dhcpclass1
rfs4000-229D58(config-dhcp-policy-test-pool-testPool)#show context dhcp-pool testPool address 192.168.13.4 class dhcpclass1 rfs4000-229D58(config-dhcp-policy-test-pool-testPool)#
| no (dhcpv4-pool-static-binding) |
Removes the DHCP pool's configured IP addresses |
| dhcp-class (dhcpv4-server-policy-config) |
Creates and configures the DHCP class parameters |
| alias |
Creates and configures network, VLAN, host, string, and network-service aliases |
