ipv6 (wlan-config-mode)
Sets the DHCPv6 and ICMPv6 neighbor discovery (ND) components for this WLAN
Syntax
ipv6 [dhcpv6|nd]
ipv6 dhcpv6 trust
ipv6 nd [header-mismatch-validation|raguard|trust]
Parameters
ipv6 dhcpv6 trust
ipv6 dhcpv6 trustEnables DHCPv6 trust state for DHCPv6 responses on this WLAN. When enabled, all DHCPv6 responses received on this WLAN are trusted and forwarded. This option is disabled by default.
ipv6 ndSets the IPv6 ND settings for this WLAN
header-mismatch-validationChecks for mismatch of source MAC address in the ICMPv6 ND message and Ethernet header (link layer option). This option is enabled by default.
raguardAllows redirection of router advertisements (RAs) and ICMPv6 packets originating on this WLAN. This option is disabled by default.
trustEnables trust state for ND requests received on this WLAN. When enabled, all ND requests on an IPv6 firewall, on this WLAN, are trusted. This option is disabled by default.
nx9500-6C8809(config-wlan-test)#ipv6 dhcpv6 trust
nx9500-6C8809(config-wlan-test)#ipv6 nd trust
nx9500-6C8809(config-wlan-test)#show context
wlan test
 ssid test
 vlan 1
 bridging-mode tunnel
 encryption-type none
 authentication-type none
 ipv6 dhcpv6 trust
 ipv6 nd trust
Related Commands
no (wlan-config-mode)Resets IPv6 ND or DHCPv6 trust parameters to default. ND request trust is disabled, ND header mismatch verification is enabled, ND RA and ICMPv6 redirection is disabled, or DHCPv6 trust is disabled.
