The local RADIUS server uses authentication schemes like PAP, CHAP, or EAP to verify and confirm information provided by a user. The user's proof of identification is verified, along with, optionally, other information. A local RADIUS server policy can also be configured to refer to an external (Lightweight Directory Access Protocol) (LDAP) resource to verify a user's credentials.
Use the (config) instance to configure RADIUS-Server-Policy related parameters. To navigate to the RADIUS-Server-Policy instance, use the following commands:
<DEVICE>(config)#radius-server-policy <POLICY-NAME>
nx9500-6C8809(config)#radius-server-policy test nx9500-6C8809(config-radius-server-policy-test)#? Radius Configuration commands: authentication Radius authentication bypass Bypass Certificate Revocation List( CRL ) check chase-referral Enable chasing referrals from LDAP server crl-check Enable Certificate Revocation List( CRL ) check ldap-agent LDAP Agent configuration parameters ldap-group-verification Enable LDAP Group Verification setting ldap-server LDAP server parameters local RADIUS local realm nas RADIUS client no Negate a command or set its defaults proxy RADIUS proxy server session-resumption Enable session resumption/fast reauthentication by using cached attributes termination Enable Eap termination for proxy requests use Set setting to use clrscr Clears the display screen commit Commit all changes made in this session do Run commands from Exec mode end End current mode and change to EXEC mode exit End current mode and down to previous mode help Description of the interactive help system revert Revert changes service Service Commands show Show running system information write Write running configuration to memory or terminal nx9500-6C8809(config-radius-server-policy-test)#
| Commands | Description |
| authentication | Configures RADIUS authentication settings |
| bypass | Enables bypassing of CRL check |
| chase-referral | Enables LDAP server referral chasing |
| crl-check | Enables a CRL (certificate revocation list ) check |
| ldap-agent | Configures the LDAP agent settings |
| ldap-group-verification | Enables LDAP group verification |
| ldap-server | Configures the LDAP server settings |
| local | Configures a local RADIUS realm |
| nas | Configures the key sent to a RADIUS client |
| proxy | Configures the RADIUS proxy server‘s settings |
| session-resumption | Enables session resumption |
| termination | Enables EAP termination on this current RADIUS server policy. When enabled, EAP authentication is terminated at the controller level. |
| use | Defines settings used with the RADIUS server policy |
| no | Removes or resets the RADIUS server policy‘s settings |
Section contents:
