Configures a captive portal mode of connection to the Web server. HTTP uses plain unsecured connection for user requests. HTTPS uses an encrypted connection to support user requests.
Both HTTP and HTTPS use the same URI (Uniform Resource Identifier), so controller and client resources can be identified. However, the use of HTTPS is recommended, as it affords controller and client transmissions some measure of data protection HTTP cannot provide.
connection-mode [http|https]
http |
Sets HTTP as the default connection mode. This is the default setting. |
https |
Sets HTTPS as the default connection mode Note: HTTPS is a more secure version of HTTP, and uses encryption while
sending and receiving requests.
nx9500-6C8809(config-captive-portal-test)#connection-mode https
nx9500-6C8809(config-captive-portal-test)#show context captive-portal test access-type logging access-time 35 connection-mode https accounting syslog host 172.16.10.13 port 1 nx9500-6C8809(config-captive-portal-test)#
| no |
Removes this captive portal connection mode |
