<DEVICE>(config)#l2tpv3 policy <L2TPV3-POLICY-NAME>
nx9500-6C8809(config)#l2tpv3 policy L2TPV3Policy1 nx9500-6C8809(config-l2tpv3-policy-L2TPV3Policy1)#
nx9500-6C8809(config-l2tpv3-policy-L2TPV3Policy1)#? L2tpv3 Policy Mode commands: cookie-size Size of the cookie field present in each l2tpv3 data message failover-delay Time interval for re-establishing the tunnel after the failover (RF-Domain manager/VRRP-master/Cluster-master failover) force-l2-path-recovery Enables force learning of servers, gateways etc., behind the l2tpv3 tunnel when the tunnel is established hello-interval Configure the time interval (in seconds) between l2tpv3 Hello keep-alive messages exchanged in l2tpv3 control connection no Negate a command or set its defaults reconnect-attempts Maximum number of attempts to reestablish the tunnel. reconnect-interval Time interval between the successive attempts to reestablish the l2tpv3 tunnel retry-attempts Configure the maximum number of retransmissions for signaling message retry-interval Time interval (in seconds) before the initiating a retransmission of any l2tpv3 signaling message rx-window-size Number of signaling messages that can be received without sending the acknowledgment tx-window-size Number of signaling messages that can be sent without receiving the acknowledgment clrscr Clears the display screen commit Commit all changes made in this session end End current mode and change to EXEC mode exit End current mode and down to previous mode help Description of the interactive help system revert Revert changes service Service Commands show Show running system information write Write running configuration to memory or terminal nx9500-6C8809(config-l2tpv3-policy-L2TPV3Policy1)#
| Command | Description |
| cookie-size | Configures the cookie field size for each L2TPV3 data packet |
| failover-delay | Configures the L2TPV3 tunnel failover delay in seconds |
| force-12-path-recovery | Enables the forced detection of servers and gateways behind the L2TPV3 tunnel |
| hello-interval | Configures the interval, in seconds, between L2TPV3 "Hello" keep-alive messages exchanged in the L2TPV3 control connection |
| reconnect-attempts | Configures the maximum number of retransmissions for signalling messages |
| reconnect-interval | Configures the interval, in seconds, between successive attempts to re-establish a failed tunnel connection |
| retry-attempts | Configures the maximum number of retransmissions of signalling messages |
| retry-interval | Configures the interval, in seconds, before initiating a retransmission of any L2TPV3 signaling message |
| rx-window-size | Configures the number of signaling messages received without sending an acknowledgment |
| tx-window-size | Configures the number of signaling messages transmitted without receiving an acknowledgment |
| no (l2tpv3-policy-config-mode-command) | Removes this L2TPv3 policy settings or reverts them to default values |
For more information on common commands (clrscr, commit, help, revert, service, show, write, and exit), see Common Commands.
The input parameter <HOSTNAME>, wherever used in syntaxes across this chapter, cannot include an underscore (_) character. In other words, the name of a device cannot contain an underscore.Section contents:
