Specify the management policy name. If a policy with the specified name
does not exist, it is created.
vx9000-3C6F18(config)#management-policy test-cw
vx9000-3C6F18(config-management-policy-test-cw)#?
Management Mode commands:
aaa-login Set authentication for logins
allowed-locations Add allowed locations
banner Define a login banner
flash-ui Enable FLASH UI
ftp Enable FTP server
http Hyper Text Terminal Protocol (HTTP)
https Secure HTTP
idle-session-timeout Configure idle timeout for a configuration session
(GUI or CLI)
ipv6 IPv6 management access restriction
no Negate a command or set its defaults
nova Enable NOVA UI
passwd-retry Lockout user if too many consecutive login failures
privilege-mode-password Set the password for entering CLI privilege mode
rest-server Enable rest server for device on-boarding
functionality
restrict-access Restrict management access to the device
snmp-server SNMP
ssh Enable ssh
t5 T5 configuration
telnet Enable telnet
user Add a user account
clrscr Clears the display screen
commit Commit all changes made in this session
do Run commands from Exec mode
end End current mode and change to EXEC mode
exit End current mode and down to previous mode
help Description of the interactive help system
revert Revert changes
service Service Commands
show Show running system information
write Write running configuration to memory or terminal
