The Wireless Appliance supports the SNMP (Simple Network Management Protocol) for retrieving statistics and configuration information.
This section describes commands which manage SNMP settings for the Wireless Appliance. These commands are located in the snmp context of the CLI.
All CLI commands cache changes. For this reason, sometimes when you make a change in a particular context, the change may not be visible immediately. If this happens, you must exit and re-enter the context in order to ensure that the database is synchronized with the latest change.
The following commands are available in the snmp context:
