Use the uapsd command to enable Unscheduled Automatic Power Save Delivery (U-APSD) on the VNS (Virtual Networks Service). Use the no form of the command to disable it. The uapsd command is accessible from the wlan:<WLAN-service-name>:qos-policy context of the CLI.
After you run the uapsd command, run the apply command to implement the changes.
enable | disable | Enables or disables U-APSD. Default value: disabled. |
This command is only available when either the 802.11e or wmm commands have been enabled. For more information see dot11e and wmm.
The following example enables U-APSD on the CNL-7-CP WLANS:
EWC.extremenetworks.com:wlans:CNL-7-CP:qos-policy# uapsd enable EWC.extremenetworks.com:wlans:CNL-7-CP:qos-policy# apply EWC.extremenetworks.com:wlans:CNL-7-CP:qos-policy# show uspsd Enable U-APSD: enable
