Use the show ospf command to display the system‘s OSPF (Open Shortest Path First) interfaces and configuration.
interface | Displays the details of all current OSPF interfaces. |
neighbors | Displays the OSPF neighbors with which the Wireless Appliance has adjacency. |
config | Displays the OSPF configuration details. |
database | Displays the OSPF linkstate database. |
The following example displays the details of all OSPF interfaces:
EWC.extremenetworks.com# show ospf interface OSPF Interface #0: Port Name :esa0 OSPF Status :Enabled OSPF authentication :None Link Cost :10 Hello Interval :10 Dead Interval :40 Retransmit Interval :5 Transmit Delay :1
The following example displays the details of all OSPF neighbors:
EWC.extremenetworks.com# show ospf neighbors Neighbor ID Router ID Priority State IP Address Interface 1 192.168.4.3 1 Full/DR 10.209.0.2 esa0:10.209.0.1
The following example displays all OSPF configuration data:
EWC.extremenetworks.com# show ospf config OSPF Area :0.0.0.5 OSPF Area Type :default OSPF Router ID : OSPF Protocol Status :enable
The following example displays OSPF information from a database:
EWC.extremenetworks.com# show ospf database Router LSA (Type 1): Link ID Advertising Router Age Sequence No Checksum Link Count 10.203.1.2 10.203.1.2 1745 0x800001c3 0xae1f 17 10.206.0.1 10.206.0.1 1525 0x8000009d 0x782e 3 Network LSA (Type 2): Link ID Advertising Router Age Sequence No Checksum 10.109.0.2 192.168.4.3 334 0x800000a8 0x781d 10.203.0.2 192.168.4.3 334 0x80000713 0xb73a Network Summary LSA (Type 3): Link ID Advertising Router Age Sequence No Checksum Route 10.2.0.0 192.168.4.3 76 0x80000080 0xd36a 10.2.0.0/24 10.2.0.0 192.168.4.9 969 0x8000007f 0xb187 10.2.0.0/24 ASBR Summary LSA (Type 4): Link ID Advertising Router Age Sequence No Checksum 10.203.1.2 192.168.4.3 1324 0x8000002b 0xd1f4 10.203.1.2 192.168.4.9 970 0x8000002b 0xa31e AS-External LSA (Type 5): Link ID Advertising Router Age Sequence No Checksum Route 0.0.0.0 192.1.5.115 806 0x80000030 0x160a 0.0.0.0/0 10.22.1.0 192.168.3.2 585 0x800006f1 0x30e9 10.22.1.0/24
