Use the create command to create a multicast filter rule. The create command is available from the topology:<named-topology>:l2:multicast context of the CLI for b@ac, b@ap, and routed topologies.
pos|default | Specifies the optional position to insert the rule. |
A.B.C.D[/0-32] | IPv6 |vocera | svp | mdns| mdnsv6 | all| allv6 | Specifies the IP address and mask of a multicast
group or that the multicast group is pre-defined.
Note: IPv6 is supported for Layer 2 bridging for both
B@AC and B@AP topologies.
ws-discovery | For ONVIF multicast discovery of the AP3916ic, indicates pre-defined multicast discovery. |
on|off | Specifies whether wireless replication is enabled. The default is off. |
This example creates a multicast filter rule:
EWC.extremenetworks.com:topology:techpubs_test_ac:l2:multicast# create 1 225.1.1.0/32 on
