stbc
Use the stbc command to enable or disable the 11n advanced STBC feature. The stbc command is accessible from all radio contexts of the CLI.
stbc enable | disable
Parameters
enable Enables the 11n advanced STBC feature.
disable Disables the 11n advanced STBC feature
Usage
  • n must be enabled in radio mode.
  • When STBC is enabled, antenna selection must be left-middle-right for AP37xx.
The following example enables STBC on radio1:
EWC.extremenetworks.com:ap:defaults:ap37xx:radio1# stbc enable
