Use the hybrid-policy command to configure RFC 3580 options. This mode enables the controller to use both a VLAN (Virtual LAN) ID in the tunnel attributes and a filter ID to select policy for a station. This command is available in the vnsmode:adminctr context.
policy | Specifies that the VLAN tunnel ID is ignored; use the topology assigned by the policy. |
vlan | Specifies that the policy used for the station is based on the VLAN tunnel ID. The filter ID is ignored. |
combined | Specifies that the policy identified in the filter ID and the topology associated with the VLAN tunnel ID are used. |
The following example sets the hybrid policy to combined:
EWC.extremenetworks.com:vnsmode:adminctr# hybrid-policy combined
