Use the local-radius command to enable or disable authentication by the defined local RADIUS (Remote Authentication Dial In User Service) server for this site. The local-radius command is accessible from the site:<named-site> context.
enable | disable | Enables or disables local RADIUS authentication. |
You must enter the apply command before exiting the site:<named-site> context for the RADIUS authentication change to take affect. The CLI prompt does not change until you exit and re-enter the site:<named-site> context.
The following example enables local authentication on site1:
EWC.extremenetworks.com:site:site1# local-radius enable
