Use the vlanid command to change the VLAN (Virtual LAN) ID of a topology group. The vlanid command is accessible from the topology group name context of the CLI.
id | Specifies a VLAN ID number. Valid VLAN ID numbers are 1-4094. |
The group member must have same topology mode type as the toplogy group.
The following example changes the VLAN ID of a topology group to 1235:
EWC.extremenetworks.com:topology:topology-group:tg1# vlanid 1235
