Use the iot-ibeacon-scan-window command to determine how long to scan in each scan interval. The scan window value must be lower than the scan interval value. The iot-ibeacon-scan-window command is accessible from within the ap:<serial> context of the CLI.
<100, 10240> | Determines how long to scan per channel. Valid values are Min (100ms) and Max (10240ms).Value must be less than Scan Interval value. Default value is 100ms. |
The IoT functionality is supported on the AP3912i, AP3915, AP3916ic, and AP3917. Enable iot-admin and iot-application ibeacon-scan before issuing this command.
The following example configures the ibeacon-scan-dest-ip address on an AP3912i:
EWC.extremenetworks.com:ap:3912000000000000#iot-ibeacon-scan-window 150
