Use the delete-ospf-interface command to delete an OSPF (Open Shortest Path First) interface object. The delete command is accessible from the ospfinterface context of the CLI.
ospf interface name | Specifies the name of the OSPF interface to delete. The name must already be created as a physical or b@ac topology in the topology context. |
The following deletes an ospfinterface with the name you specify:
EWC.extremenetworks.com:ip:ospf:ospfinterface# delete-ospf-interface top1
