Use the iot-antenna command to configure the IoT antenna on the AP3915e and AP3917e access points. The iot antenna command is accessible from within the ap:<serial> context of the CLI.
antenna name | Name of the IoT
antenna. Valid values are:
If there is no antenna, the value is No Antenna. |
The following example configures an IoT antenna on an AP3915e:
EWC.extremenetworks.com:ap:1722D10010810000:professional_antenna# iot-antenna ML-2499-HPA8-01 EWC.extremenetworks.com:ap:1722D10010810000:professional_antenna# show Professional Antenna Install: Antenna Type Radio 1/2 Port 2.4G/5G-1 Antenna Type ML-2452-PNA7-01R 8/12dBi 68deg Panel Radio 1/2 Port 2.4G/5G-2 Antenna Type ML-2452-PNA7-01R 8/12dBi 68deg Panel IoT Antenna: ML-2499-HPA8-01
