show
Use the show command in the professional_antenna context to display the antenna configuration for the selected AP.
show
Parameters
There are no parameters.
The following example lists the antenna configuration for the AP 37xx.
EWC.extremenetworks.com:ap:1111111111137152:professional_antenna# show
Professional Antenna Install:
Antenna                      Type
Radio 1 Left Antenna Type    PRO-AI-DT05120 AG 5dBi 120deg 3f
Radio 1 Middle Antenna Type  No Antenna
Radio 1 Right Antenna Type   No Antenna
Radio 2 Left Antenna Type    PRO-AI-DT05120 AG 5dBi 120deg 3f
Radio 2 Middle Antenna Type  No Antenna
Radio 2 Right Antenna Type   No Antenna
Refer to user for descriptions of the values in the various columns of this output.
