Use the filter-ip1 to filter-ip4 commands to set four IP addresses as a means to filter packets for capture. When specified, only those packets that are received, transmitted, or both to and from the specified IP addresses are captured.
filter-ip1 IP Address to filter-ip4 IP Address | Specifies IP
address packet capture filters. You can specify four IP addresses as a means to
filter packets for capture. Both IPv4 and IPv6 address formats are
supported. Note: The filter-ip1, filter-ip2, filter-ip3, and
filter-ip4 filters are mutually exclusive and are applied in a specific
order. The filter-ip1 is applied first. If no match is found, only then is
filter-ip2 is applied and so forth.
After you create the IP Address filters, use the use-filter-ip1 to use-filter-ip4 commands to apply the filters.
The following example configures the filter-ip1 filter on the wireless AP AP3912i:
EWC.extremenetworks.com:ap-traffic-capture# filter-ip1 192.168.13.13
