Use the iot-ibeacon-scan-uuid command to configure the minimum signal strength required for successful connectivity. The iot-ibeacon-scan-uuid command is accessible from within the ap:<serial> context of the CLI.
<UUID> | Identifier used to differentiate a large group of related beacons. A company can have a network of beacons with the same UUID. Forwards to the Application Server the data from UUID that matches the configured value. Filters out all other UUID data. If UUID configured value is all zeros, no filtering occurs. |
The IoT functionality is supported on the AP3912i, AP3915, AP3916ic, and AP3917. Enable iot-admin and iot-application ibeacon-scan before issuing this command.
The following example configures the iot-ibeacon-scan-uuid on an AP3912i:
EWC.extremenetworks.com:ap:3912000000000000# iot-ibeacon-scan-uuid 985123a0-7e4f-11e7-9022-fb7190c856e4
