Use the upgrade apup command to upgrade the software of the Wireless AP, and use upgrade apup-camera to upgrade the camera on the AP3916ic. The upgrade apup and upgrade apup-camera commands are accessible from the root context of the CLI.
No parameters are necessary when upgrading the AP camera. Command defaults to the camera on the supported AP3916ic.platform | Specifies the platform of the Wireless AP. |
filename | Specifies the file name of the new image. |
number | Specifies an ordinal image number returned by the show apup command. |
ap_serial# | Specifies the serial number of the Wireless AP. |
The following example upgrades a Wireless AP:
EWC.extremenetworks.com# upgrade apup AP3705 1 ap 0122003999382
EWC.extremenetworks.com# upgrade apup-camera
Caution
Upgrading an AP disconnects any clients currently using the AP. Following the upgrade, the AP reboots.
