Use the create command to create a new VNS (Virtual Networks Service). This command is available in the vnsmode context. After you create a VNS with this command, you can configure additional parameters in the vnsmode:<named-VNS> context. Refer to <named-VNS> for more information.
After you run the create command, run the apply command to implement the changes.
vns name | Specifies a name for this VNS |
wlans WLANS name | Specifies a WLAN (Wireless Local Area Network) Service for this VNS |
pol role-name | Specifies the non-authentication role for this VNS |
When you create a VNS, if the referenced WLAN Service has a mode of:
The following example creates a VNS named testvns and assigns it a WLAN Service named “EWC-1” and a role named “NonAuth”:
EWC.extremenetworks.com:vnsmode# create testvns wlans EWC-1 pol NonAuth
