Use the create command to create a RADIUS (Remote Authentication Dial In User Service) server configuration. The create command is accessible from the vnsmode:radius context of the CLI.
name | Specifies the name of the RADIUS server |
A.B.C.D | Specifies the IP address of the RADIUS server |
secret | Specifies the shared secret for the RADIUS server |
The following example creates and then displays the details of a RADIUS server configuration named test-radius-server with an IP address of 10.10.10.10 and a shared secret of “test”:
EWC.extremenetworks.com:vnsmode:radius# create test-radius-server 10.10.10.10 test EWC.extremenetworks.com:vnsmode:radius# test-radius-server EWC.extremenetworks.com:vnsmode:radius:test-radius-server# show Authentication port: 1812 Accounting port: 1813 Authentication priority: 5 Accounting priority: 5 Authentication total number of tries: 3 Accounting total number of tries: 3 Authentication RADIUS request timeout: 5 Accounting RADIUS request timeout: 5 Interim accounting interval: 0 Default protocol: PAP Shared secret: **** Name: test-radius-server
